1995 ..dodge 360 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2012, 11:43 PM
1995 ..dodge 360
got a question i got a chance to get a 1995 dodge ram 2500 360 engine i would switch it to carborated what would be hp difference stock is 230hp and 330tq thanks
Old 05-03-2012, 12:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
With no other changes except carb instead of EFI, the peak HP will be basically unchanged. I'd be surprised if there were a 5 HP diff either way, unless there were other changes like cam, headers, etc.
What you might be losing is seamless cold start up and overall drivability- the EFI can beat a carb for those things, including mileage and emissions. Depending on the static compression ratio, there could be a problem with detonation w/o the knock sensors. Better octane might be enough to offset the loss of knock sensors but if it isn't, using less total timing will hurt power, in some cases a LOT. But that remains to be seen.
To use a carb will also usually mean a different distributor will be needed to bypass the ECM.
The Following User Says Thank You to cobalt327 For This Useful Post:
fordss (10-08-2012)
360 out of a dodge durango shadow120 Engine 5 09-10-2009 12:47 PM
need help with dodge 360 legionlleh Engine 2 02-06-2007 09:53 PM
360 Dodge bogs? tm454 Engine 2 10-09-2004 07:20 AM
is my dodge 3.9L V6 worth keeping or should i go for a dodge 360??? mopar_101 Engine 2 07-25-2004 11:04 AM
dodge 360 rebuild hogan400 Engine 1 06-04-2003 02:36 PM
