1995 gmc 2500 4L80E - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2007, 01:46 PM
1995 gmc 2500 4L80E
hey guys I cant find a used 95 80e trans around close for sale. parts supplies say only 95 works on this 2500 with 5.7 will a 97 4L80E interchange and what do i have to change
Old 10-18-2007, 04:21 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Don't see why not. As long as the tranny comes from behind a traditional small block (not the LSx based engines) you should be fine. There might have been a slight difference with an electrical plug or something, but the trannys should be interchangeable
Old 10-18-2007, 09:43 PM
1995 gmc 2500
guy had one out of motor home prob. big block 454 had 11,000 miles wish it would work for $650
Old 10-18-2007, 11:50 PM
curtis73's Avatar
Wiki Edits: 16
It should work just fine. No difference between bbc and sbc trannys
Old 10-19-2007, 06:30 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there is a bit more to check out than bolting up to the engine..
check the shifter linkage arm length.... the 97 will have a long arm because the MLPS is bolted to the case.
Cooler line connections are different. The 1997 is a center lube design trans. One cooler (pressure OUT) line at the bell housing area.... second cooler (RETURN!) line towards the rear of the case......There is a Sonnax conversion kit that makes this easy. Hooked up incorrectly will equal a smoked trans gear train.
These are "clip on - snap in " style cooler fittings they can NOT Be changed. The rear cooler fitting is a longer design to fit into the trans case deeper for proper lube. There are adapters available to use a thread on style cooler fitting design
Check the electrical connector.... there is an early and late design. The 1995 should have the late design too ....Early design has a screw in the center of the plug on the vehicle side of harness.... check it
Old 10-19-2007, 12:10 PM
curtis73's Avatar
Wiki Edits: 16
whew... I love it when Crosley saves the day with way more information than I can retain
Old 10-19-2007, 05:03 PM
great info
thanks guys, looks like i 'll buy me a trans. my trans shop probably knows all that but i like knowing myself .i pulled old one put in seals but pump is spraying like heartbeat. trucks got 285k on it motor runs ok maybe 1 qt. oil 6or7 weeks hard driving.
1995 5.7 litre 4 wheel drive GMC suburban J. Tyler Engine 3 08-08-2007 10:42 AM
GMC Sierra 2500 snydrobert Introduce Yourself 2 07-01-2007 08:43 AM
'71 Gmc 2500 mercflathead Engine 16 01-08-2007 09:55 AM
1995 GMC No Spark 78Z Engine 1 01-24-2005 05:21 AM
1972 GMC 2500 Whats it worth? propaniac Hotrodding Basics 5 12-21-2003 11:45 AM
