1995 GMC trans problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2010, 06:05 PM
I'm looking at a V6 automatic truck for sale here that doesn't have reverse. The truck has 65k miles and is ok otherwise, is this a common problem? Could this be something simple to fix [ie no trans removal] or does the trans need to be removed? Any ideas why reverse does work?
This could be a cheap truck if the fix is simple or i might have to keep looking.
TIA, Todd.
Old 03-17-2010, 10:34 AM
Rexnfx's Avatar
I'm sure trans would have to come out, for a no reverse complaint.
Old 03-22-2010, 02:36 AM
no reverse usualy mean reaction shell is broken.about $25-50.Trans need to come out
88 S10 Blazer Trans problem wahamilton87 Transmission - Rearend 4 06-12-2009 07:13 PM
1995 Impala Rebuilt Transmission Shift & Noise Problem Mobbvalous Transmission - Rearend 2 12-31-2008 04:50 PM
Trying to diagnose problem: trans or engine? adryan16 Transmission - Rearend 16 11-11-2008 10:07 AM
buick super turbine 300 trans. problem skylark65 Transmission - Rearend 2 02-10-2007 02:39 PM
Auto Trans Intermittent No Output Problem joeycam Transmission - Rearend 6 01-06-2006 06:05 AM
