1995 mustang...rear brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2011, 02:13 PM
1995 mustang
im having a problem with rebuilding rear calipers on my stang,the parts i get with kit have the wrong size o rings,have been to 3 parts stores with the same kit.only thing i can fgure out is the rear end has been changed, my question is how do you read tag to see what year it is...thanks for any help
Old 03-05-2011, 05:58 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
What are the numbers on the tag...
Old 03-05-2011, 07:28 PM
1995 rear end
top no#s264c
below # 273 75 5f08
Old 03-06-2011, 08:14 PM
tag numbers
5264c / 273 75 5f08
Old 03-06-2011, 11:01 PM
Sure the o-rings are the wrong size? I'm sure you'll have to stretch them pretty good to get them to go on. You could always go to a place that sells o-rings and get the correct size Viton o-rings if you think they arent the right size.
As cheap as calipers are why are you rebuilding them instead of replacing them? Are they alot more expensive than most calipers are?
An expensive caliper to me is anything more than $25. A kit is cheap but unless you have the tools to check everything out, bore it if needed, dip/blast it clean, etc then its probably best to just get a new caliper...
By the way where in Missouri are you?
Old 03-07-2011, 08:30 AM
brakes
i live a few miles from fort leonard wood and prices around here for anything are high,the cheapest new/rebuilt calipers i have found are $39.99 each, all i did was mess up one of the rings trying to get the piston back in,the rings that are in kit are way to big.thanks for your responce,this car has been nothing but a night mare since day one,ill never own another one.
Old 03-12-2011, 06:40 PM
Did an online search and $40 seems to be a good price for the rear calipers. Rear calipers are always more expensive (probably due to the parking brake in them).
Engine Swap for a 1995 Mustang. V6 for a 302 Flemenjo Engine 8 07-30-2010 05:44 AM
1995 mustang bear1980 Body - Exterior 0 10-23-2008 12:00 AM
1995 Mustang fuses ArmyofOne Electrical 2 09-22-2004 11:52 PM
1995 LT1 Custom95Z Engine 2 02-16-2003 08:34 AM
wiring harness 1995 mustang gt stangfiend Electrical 1 01-07-2003 10:07 PM
