1995 olds 3800 series 2 troubles
my olds has a hesitation when trying to pass or is under load.
1) no check engine light 2)replaced fuel pump-filter and pressure reg 3)replaced plugs-wires and coils 4)replaced throttle position-idle air- mass air sensors 5)replaced all known rubber vacuum tubes 6)it has 17 millibars of vacuum at the manifold 7)unknown fuel pressure 8)have not changed oil pressure-tcc-carbon canister or return fuel lines 9)ruff idle at start-up 10)have not changed crank or cam sensor ANY IDEAS? I HAVE RUN OUT |
| 3800 Series II issue. | kc8oye | Engine | 4 | 12-20-2010 03:18 AM |
| 3800 series 2 | runn141 | Engine | 25 | 05-06-2009 07:56 AM |
| 3800 series revving up on it's own | 78novaman | Engine | 12 | 12-29-2008 05:22 PM |
| 3800 series 2 | stshoops | Hotrodding Basics | 1 | 12-29-2008 04:07 PM |
| Series II 3800 | Scuzzy | Transmission - Rearend | 2 | 06-15-2004 10:55 PM |
