1995 S 10 Blazer 4.3 Vortex - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2008, 11:00 AM
Hi every body I am a machinist by trade but New cars got by the butt!
lol I did a tune up plugs and wires and also new muffler from the yolk out.
And the muffler gets hot fast ? got any suggestion's
Old 05-10-2008, 02:31 PM
poncho62's Avatar
Wiki Edits: 5
welcome......Not sure that I understand the question, but you should probably ask it in the engine forum.
Old 05-10-2008, 06:25 PM
1995 S10 Blazer4.3 v6 vortex
I changed water pump and thermostat, changed plugs and wires. put 2 shifting selanoids in also, Then i patch the muffler and the cheek engine light out, til the stuff i used harded like a cast on ur leg then it started missing and idleing funny from 1k to 750rpms and running real ruff at a idle only! Does anybody have a easy fix for me?
Thank you Poncho62 for ur in put.
BrettC49
Old 05-10-2008, 07:51 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Check to make sure the rear plug wire on the passenger side is on the spark plug, and not jammed in between the plug and head. Don't ask me how I know this please. It is just easy to do because it is so hard to get to it in the first place.
1995 chevy s10 blazer 4x4 v6 trans problems SonnyFaust Transmission - Rearend 7 11-27-2007 07:56 AM
Brake lights switch oldsmo Electrical 4 10-19-2006 12:23 PM
wiring a v8 up in a s 10 blazer wolfinwv Electrical 5 01-22-2006 03:11 AM
Blazer S10 4.3 idles poorly bigjack Engine 1 03-30-2003 09:38 AM
