Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1995 S10 4.3 4L60E Transmission problems
Old 01-20-2011, 10:30 AM
falcone falcone is offline
Ok i found out that the O-ringed Valve (that is pictured above) to put in Valve body to convert to On/Off style Lock Up is actually made by Teckpak.... now would anyone know if the circuit in the valve body for the lock up valve is the same between early 95 valve bodies and 99 valve bodies?
