1995 suburban 1500 series 4by - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2007, 02:41 PM
Tyler
I have a 1995 suburban half ton four wheel drive. It keeps warping the front rotors. I have replaced both front brake lines,master cylinder, & pads. I replaced the pads & rotors twice & both times they warped & also the original rotors warped & I had them turned & they warped again. I know the calipers can warp the rotors, but I find it hard to believe that both sides would stick at the same time. I would hate to replace them & the rotors warp again, because they are expensive. The replacement rotors & brakes came from Autozone & I'm wondering if they are made from cheap materials & that's my problem. Also the antilock brake light stays on, but I don't know if the abs system going out can cause warped rotors. Has anyone had similiar problems on a Suburban or 1500 series four wheel drive truck? j tyler, Any help will be greatly appreciated. cheers
Old 08-07-2007, 07:42 PM
poncho62's Avatar
Wiki Edits: 5
moving to brake forum
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
1995 5.7 litre 4 wheel drive GMC suburban J. Tyler Engine 3 08-08-2007 10:42 AM
