1995 TBI 383 Chevy Intake Manifold
Do I need a 1996 - later sbc intake manifold or a pre 1987 sbc intake for a 1995 tbi sbc? Or are they there own thing?
Thank |
if it has the '87-'95 heads, then you need a factory TBI manifold, or Edelbrock also makes sort of an upgraded intake but it's still basicly the same.. if it has Vortech heads, then you need a GMPP Vortech- TBI intake, and if it has pre '87 heads ( perimiter valve cover bolts ) then you will need a basic 4bbl with a TBI adapter
Sorry, I should have explained myself better. I was looking for a carbureted intake manifold. Sorry for the confusion. I was just using the term "TBI" to describe the heads. I should have worded the question differently.
Thanks |
the only carburated intake manifold for the '87-'95 Swirl port TBI heads I know of is the Holley Street Dominator 300-64 Manifold. However, I would not buy a manifold for those heads. just modify a standard pre '87 manifold, like an Edlebrock performer, and then ditch those heads as soon as you can
There's lots of head choices out there, the original GM Vortec is really popular but there are a lot of aftermarket heads as well that provide equivalent to superior performance. To avoid having to go back and redo the configuration, you should really do the heads first if you haven't already. As manifolds go the Performer RPM is one of the better solutions in my opinion, it offers solid upper RPM gains without trading that for high losses on the bottom end, this is hard to find, intakes usually provide bottom end torque or top end horsepower not both. The Swirl Ports can be pocket ported and the vane removed. This is a lot of work, but is effective and has a following, it even used to have an active blog site years ago. But time is moving away from these engines and the glee club apparently has moved on to other things. Bogie |
I am building this motor to go in a 4X4 mud truck with a redline of about 3800. Would it be worth it to get newer vortec heads?
Thanks |
| 4-71 supercharger intake manifold for S.B. Chevy | thumperdave | Engine | 1 | 04-12-2008 11:56 AM |
| chevy 350 intake manifold question | sparkyct55 | Engine | 5 | 02-14-2008 05:07 PM |
| Chevy 350 Intake Manifold Gasket | morenbd | Engine | 4 | 07-11-2004 05:05 PM |
| Cam and Intake Manifold for a Chevy 305? | Mike_82 | Engine | 8 | 10-07-2003 09:06 PM |
| BBC intake manifold vs. '62 Chevy hood ? | Hippie | General Rodding Tech | 0 | 05-18-2003 08:54 AM |
