1995 Z71 different gear ratios front to back,is there a IFS 3/4 ton 6 lug bolt in? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-03-2012, 02:34 PM
Ifs
gm has a 825,1/2 ton ifs and a 925 IFS,3/4 ton,You should be able to change the ratio in the one you have or find one with the correct ratio,It should be a bolt in deal.
  #17 (permalink)
Old 01-07-2012, 06:24 AM
chevy1500z71's Avatar
Originally Posted by allsouth88
I just picked up a '95 Z71 and it has a couple issues. The front IFS is a 3.73 and the rear 10 bolt is a 4.10. I dont have a great deal of money to spend so am not looking to throw in a solid axle up front or throw in lockers. Its got a 6" lift and running 35" tires.
I am needing to know if there is an IFS 3/4 ton 6 lug to put in. How much do I need to change and how much a pain in the arse it would be.
Thanks for the help.
6 lug trucks never came with the 9.25" front end. heavy halfs had 3/4 ton rear ends with 6 lug, 8.25 front and half ton transmissions while light duty 3/4 tons had the same thing, except with the 3/4 ton transmission, still a 6 lug with 8.25 front.
swapping to the front end you want requires alot more then its worth. you would have to fab new mounts for the diff, and change your knuckles to accept the 3/4 ton unit bearings, which in turn requires the matching control arms. basically the only thing you can keep it going to be your upper control arms and your torsion bars, everything else is different. .
It would make more sense to just do a solid axle swap. If you wanted to settle for a dana 44, they are easier to find in driver side drop and you can re use your transfer case, steering box, ect. all you have to do is hang leaf springs and fab a simple crossover steering setup. on junkyard springs and .120 wall dom for the steering you could do a job like this for under 1000 bucks. to do the ifs conversion you would end up spending a little more i would imagine.
gear ratios american muscle rulz Transmission - Rearend 0 07-07-2007 03:38 PM
How do these gear ratios look? rlackey Transmission - Rearend 2 04-24-2005 08:33 PM
gear ratios in a 4x4 front vs. rear.... crazy larry General Rodding Tech 3 04-15-2005 07:30 PM
Truck 12 bolt gear ratios SAATR Transmission - Rearend 4 01-15-2004 11:52 AM
gear ratios Blag Transmission - Rearend 2 02-09-2003 04:59 AM
