Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996-2000 vortec block build
Old 11-12-2012, 02:25 PM
hpete hpete is offline
For your stated goals the vortec is a great choice. The crank and rods are strong enough and the pistons are fine if you can get the compression to fit your needs. If you can find one with 4 bolt mains (1 ton) that's better but 2 bolts will work fine.
