Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996-2000 vortec block build
Old 11-15-2012, 08:36 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by ss396si View Post
Then down the road change the top end.I can transfer parts from the 305 to this motor.
Be careful here. Bolting the 305 heads to a 350 block and using a short duration stock cam could raise the dynamic compression ratio into the threshold of detonation, depending on fuel quality. Resist any thoughts you may have of using two head gaskets to lower static compression ratio. That'll just make it worse.
