Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996-2000 vortec block build
  #19 (permalink)
Old 11-16-2012, 10:59 AM
ap72 ap72 is offline
Banned
Originally Posted by 1Gary View Post
AP- I am going to respectfully disagree with you on the ring sets long term and I know with 3.48 stroke as oil ring spacer isn't used,so in that case a 6" rod could be used.I did think I read he was if with a SBC going to stroke it.
As I posted,I suggest he goes with a BBC.
I appreciate you being civil about the ring issue, but all of the data collected by all of the major car manufacturers shows that you're wrong. They're switching to thinner rings for a reason- more power, better sealing, less bore wear, and as a result better emissions. Many of them are also switching to steel rings (a lot of foreign cars have used steel rings for decades).
The singular advantage thicker rings have is cost. for sbc's a cast iron 5/64ths ring set is still the cheapest set by a LONG shot.
