Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996-2000 vortec block build
  #23 (permalink)
Old 11-17-2012, 10:24 AM
ap72 ap72 is offline
Banned
Originally Posted by 1Gary View Post
A proper gaped 5/16 compression ring for it's application is going to provide 7 to 8 pounds of tension.
Certainly ring material,our competent properly prepped cylinders all come into play in the final sealing power.
We don't go by OEM standards when that hasn't been the point of hot rodding from the beginning of time to current.Some of the stuff they do is just pure cost cutting.
These comments are related to first gen blocks and street/strip applications.
Most people use the OEM standard as the lowest acceptable standard- they try to do better. In fact, you're the first hotrodder I've found that sets their standards as higher than the target.
If you want to know all of the why's on why thinner rings are superior then call Total Seal- they've never steered me wrong and I'm sure they'd be glad to help you out too.
