1996 4.3 vortec v6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2005, 10:49 AM
1996 4.3 vortec v6
hello, i got a 4.3 rebuilt and i am trying to run a short shaft water pump there wont be any serpentine belt jest a fan belt running the alt. problem is the pullies i have are offset , dont line up. can i change the harmonic balancer, or go to the long shaft pump. putting this in a 1930 ford model a, so room is a problem. thanks Dave
Old 12-15-2005, 07:32 PM
David, how far off are the pulleys? I take it that the Balancer pulley is out farther than the water pump?
Chris Laarman
Ottawa Engine and Performance
www.ottawaengine.com
Old 12-15-2005, 08:33 PM
Bumpstick's Avatar
Hammer and a torch
Most likely you have long pump pulleys so the short pump wont work with them... Either have to change pulleys for a short pump or go with the long pump...
bore & stroke a GM 4.3 V6 awannf Engine 11 11-08-2009 06:34 PM
4.3 vortec v6 David G Engine 6 12-15-2005 04:18 PM
4.3 vortec v6 86z28T56 Engine 3 01-04-2005 05:33 PM
96 vortec 4.3 to 97 vortec 454 rtrooster Electrical 0 01-07-2003 08:38 PM
4.3 v6 CARGUY Engine 2 06-05-2002 07:17 PM
