1996 Blazer 4x4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2009, 09:56 PM
brian berwick's Avatar
1996 Blazer 4x4
Wanted to know if anyone knows if the spindles and rotors off 1987 s10 pick up would bolt on to 1996 Blazer control arms to make it 2 wheel drive as its going to be a winter project It has no tranny or transfercase or front axle but has great body and glass rare in my part of Canada going to make a panel truck like HHR aready have a 4x4 Blazer any help would be great
Old 09-09-2009, 10:15 PM
fast68's Avatar
likes chevy trucks & boobies
make sure tie rod end holes are in same location
make sure balljoints are same between the two trucks
make sure overall height of the spindles is same
make sure you can bolt the calipers on and if you have to swap them the make sure the hose ends are same on both trucks
i would not think they are the same
one interesting fact i found out a few months when i owned an 85 buick riviera is that the spindles on those mid sized frnt wheel drive cars are the same as the 82 83 84 4x4 s10 pickups and blazers
the toronados as well..
never knew..
and very odd.. haha
try http://car-part.com for looking up and comparing parts like this and vehicle applications
i use the site like an interchange manual all the time
and you can sort part results by years as well
good luck
Old 09-13-2009, 11:22 AM
opus70's Avatar
S-10 ??
The easiest and cheapest way is to get the front cv axles and gut them and reinstall just the ends through the wheel bearings.u can cut the cups off the inside as u see fit. then its 2wd and the wheel bearings wont come apart.
The cv axles hold the bearing and spindle press fit in place,without the axle syub and nut torqued in place the spindle will walk out and it will be ugly.
1996 Blazer 4x4 engine brian berwick Engine 1 08-22-2009 10:22 AM
Header Help for a 85S10 Blazer 4X4 VCamm Engine 2 06-27-2006 11:02 AM
how do I fix 4x4 in a 91 blazer 1961_MGA Transmission - Rearend 2 01-26-2004 07:24 PM
1996 4 door s-10 blazer mural/pattern help ChrisMiddleron Body - Exterior 0 12-14-2003 12:34 AM
1996 Chevy 4x4 s-10 Blazer ChrisMiddleron Body - Exterior 0 10-12-2003 12:03 PM
