Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996 Blazer electrical question
Old 03-08-2013, 08:32 PM
EOD Guy's Avatar
EOD Guy EOD Guy is online now
You might have a short somewhere......... I'd start by un-hooking anything that was spliced into the OEM wires..... ie radio, amps, lights etc..... see if you still have the issue. If the issue goes away, then hook them back up one at a time to locate the faulty circuit.
Use a flashlight and look at the cable that comes from the battery to the starter, the wire from the starter to the fusebox as those are hot at all times, look for any melted wires under the dash.
