Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996 Blazer electrical question
Old 03-08-2013, 09:20 PM
crownver crownver is offline
I'm thinking there is a draw somewhere in your system. A short to ground would likely burn out the wire that was shorted.
I would pull the positive battery cable and put a test light or an ammeter between them, then start pulling fuses one at a time, until the light went out or the ammeter went to zero. At least then you know what circuit to be looking at.
