Man that's some draw. I assume you checked the, cable from the battery to the starter and fuse blk and they were ok. I also assume you are charging the battery back up with a charger...... so with a fresh charge on the battery, after 20 min, battery hooked up, place your hand on the alt housing, if it's warm, you prob have a short in the internal regulator etc....... Has the alt been replaced/ rewired lately?
Did you remove the remote starter completely?
