1996 blazer front end and lights. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2010, 07:55 AM
im about to buy a 1996 2door Chevy blazer from a friend of mine. It has the square headlights in the front... I've seen several blazers around and on the internet that has the long rectangular headlights and was wondering if i could change the front of the blazer from the square headlights to the longer rectangular lights?
i want http://www.theautochannel.com/media/...zer_lt_4dr.jpg
verses
http://www.theautochannel.com/media/..._blazer_2d.jpg <---- what it currently has
Old 10-18-2010, 04:41 PM
It is possible, I just can't recall which parts all have to be changed in order to make this swap.
Old 10-19-2010, 10:40 PM
You're gonna need the headlights, parklights, grille, and probably the radiator support. The bumpers will also be a different design. You'll want the parts from a 1998 or newer S10 Blazer/S10 PU.
Old 10-26-2010, 06:19 AM
Awesome thanks for the advice.. will it all simply just bolt on?
Old 10-28-2010, 10:47 PM
The support is just a bolt on radiator support, the fenders are the same.
So its a pretty straight forward bolt on parts and your done. The Chevy and GMC hoods are different but should all bolt on the same.
Old 10-29-2010, 12:12 PM
ahh ok thanks
Rear Leaf Spring Installation on 31 Ford 31fordcoupe Suspension - Brakes - Steering 32 04-24-2009 08:08 PM
1966 Impala w/a '65 front end. Need advice. c-towndave Body - Exterior 1 01-02-2009 06:06 AM
Cheyenne to Silverado Front end ok4ayl Electrical 3 11-09-2008 08:51 AM
Having problems with the tail lights... HammerGVette Electrical 3 04-17-2007 01:06 AM
mustang 2 front end ridener Body - Exterior 1 10-30-2001 08:15 AM
