1996 c220 mercedes engine problem
The wiring harness has been replaced but now car engine surges
Will ramdomly rev up even after warmed up Happens when in drive then you get NO Throttle response till you restart car How to Fix |
Does the ASR light come on when the problem occurs?
Sounds like maybe the egr or the iac is acting up. I would test the egr and make sure its working properly. Sounds like it may be leaking or opening at the wrong time.
c220 random reving
No that light does not come on
Can I switch engibes to a C230 ??? |
Does the ASR light ever come on, like before the engine is started?
Does it work. I have a hunch the bulb is out. Probably a bad throttle body/TPS assembly |
| All times are GMT -6. The time now is 05:02 PM. |
