1996 c220 mercedes engine problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2013, 11:23 AM
The wiring harness has been replaced but now car engine surges
Will ramdomly rev up even after warmed up
Happens when in drive then you get NO Throttle response till you
restart car
How to Fix
Old 01-18-2013, 05:07 PM
LATECH's Avatar
Does the ASR light come on when the problem occurs?
Fact is stranger than Fiction
Old 01-18-2013, 07:49 PM
hcompton's Avatar
Old & Furious
Sounds like maybe the egr or the iac is acting up. I would test the egr and make sure its working properly. Sounds like it may be leaking or opening at the wrong time.
Old 01-21-2013, 08:42 AM
c220 random reving
No that light does not come on
Can I switch engibes to a C230 ???
Old 01-21-2013, 06:04 PM
LATECH's Avatar
Does the ASR light ever come on, like before the engine is started?
Does it work. I have a hunch the bulb is out.
Probably a bad throttle body/TPS assembly
1996 Chevy Cheyenne engine problem... kcase Engine 1 01-09-2013 05:41 PM
1996 Ford Taurus Transmission Problem tim0215 Transmission - Rearend 3 11-24-2011 08:53 AM
Mercedes W140 Engine Swap (65AMG) expand Engine 1 05-25-2010 12:47 AM
Older Mercedes, engine swap Faust Engine 4 01-04-2007 01:35 AM
engine conversion, mercedes to chevy Woosung Engine 2 06-11-2002 02:26 PM
