1996 chevy blazer. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2010, 07:36 AM
1996 chevy blazer.
im about to buy a blazer from a friend. she has told me that the break lights do not work and the turn signals do not work, she said she has changed all the fuses but still nothing i was wondering how hard it would be to rewire them?
Old 10-18-2010, 02:50 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Make sure the bulbs are good.
1- The two problems may not be related. Bad flasher and bad brake light switch.
OR 2- the two problems may be related. Bad turn signal switch.
If the hazard flashers don't work look at item 2.
If the hazard flashers work look at item 1.
See attached diagram.
vicrod
Old 10-26-2010, 06:20 AM
Ok thanks!
Old 10-27-2010, 02:49 PM
ok what im being told now and what ive seen is the turn signals work but the break lights dont.
Old 10-27-2010, 08:53 PM
If the turn signals work and the taillights work, then
the brake light switch must be at fault.
The switch is probably located under the dash, attached
and activated by the brake pedal. Very simple to replace.
4L60-E w/4.3L v6 1993 chevy blazer cliffb Transmission - Rearend 2 01-27-2009 05:20 PM
New member with a Chevy Blazer nkazerou Introduce Yourself 1 10-17-2008 11:39 AM
1996 blazer fuel issues brian berwick Engine 1 08-18-2008 04:04 AM
1973 chevy blazer hoosier kennels Introduce Yourself 2 01-21-2006 08:42 PM
1976 Chevy Blazer Gas Milage chevracing Engine 2 05-21-2003 08:15 AM
