1996 Chevy Blazer S-10 Tilt Steering Column - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2013, 07:47 AM
Last journal entry: 1952 Chevy Street Rod Truck Build
I put a 1996 Chevy Blazer S-10 tilt steering column in my 1952 Chevy truck build. Column has gone bad w/
bottom bearing problem. I wired the column to my wiring. Column has two plug in wiring modules that will unhook and plug into a same column. Any other years the same as the 1996??? I've been told not to try repairs to the bottom bearing. Any feed back?? Thanks.
Old 09-01-2013, 12:45 PM
IDIDIT and Flaming river both use GM connectors.
The Following User Says Thank You to 46streetrod For This Useful Post:
NickO (09-02-2013)
Old 09-01-2013, 12:47 PM
ogre's Avatar
the 'Duracell Project'
s10 columns are a dime a dozen
tape a few measurements and hit the bone yards
The Following User Says Thank You to ogre For This Useful Post:
NickO (09-02-2013)
56 Chevy Tilt Steering Column Swap slickstick56 Suspension - Brakes - Steering 1 05-04-2009 09:24 AM
Tilt Steering Column Theresa Shank Suspension - Brakes - Steering 2 10-10-2006 10:45 AM
1990 Full Size Blazer Steering Column problems..tilt boneyard Buick Suspension - Brakes - Steering 5 02-08-2006 10:39 PM
Chevy Tilt Steering Column James Groves Suspension - Brakes - Steering 1 11-20-2001 04:12 PM
