1996 Chevy c1500 4L60e problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2009, 04:41 PM
Hey. I have a 96 Chevy c1500 with a 305 in it with 200,000 miles on it and I don't know the repair history its an old state truck, I have only put about 10,000 miles on it since I bought it. I believe I have a 4L60 in the truck. I have a problem with the tranny. It won't downshift when I stop at a light or slow down (I can shift it manually). When the truck is cold it works fine but after it warms up is when I start having problems. I changed the tranny fluid hoping it would do something but no dice. I didn't think it would help but I tried. My next idea is that there is something wrong in the valve body but I don't want to start tearing it down until I know that's it and not something else. I'm out of work right now and don't have all that much money to get a new tranny, probably not even a used one and this is my only vehicle so I can't have it down for too long. Thanks for any help you can give me.
Steve
osiris419@gmail.com
Old 10-03-2009, 05:00 PM
Also the check engine has been on for o2 sensors so I don't know if the tranny is throwing codes or not. Or even if it would turn on the check engine light if it did.
Old 10-05-2009, 02:01 PM
fast68's Avatar
likes chevy trucks & boobies
fhgfhgfhgdggghf
Old 10-05-2009, 02:11 PM
Thanks. I'm going to get it rebuilt. My old college professor is teaching an automatic transmission class with his auto tech students and is going to take my truck as a training aide. They are going to go through it and troubleshoot it and overhaul it. All I have to pay for is parts.
Old 10-05-2009, 06:06 PM
This is not a transmission for children to learn on, this thing is wickedly complex, it is basically a computer directed, electrically managed, hydraulically controlled version of the mechanically managed, hydraulically controlled 700R4. Basically, the 4L60E includes the nightmare of the 700R4 with all that electronic/electrical stuff on top of it. Part of the controls both electric and hydro-mechanical are inside, with electronic to electrical controls strapped on the side. The functional schematics of this thing show all that stuff as inside a box called a valve body, the average guy doesn't even know that part of the "Valve Body" is on the outside. It does not take kindly to people who are ignorant of it. This is a good way to end up owning a piece of expensive junk.
At 200,000 miles it's given it's all, that's well over the design life expectancy. Franky, since you don't know how a junk yard tranny has been treated, and if it has many miles on it the probability of it, also, needing a rebuild is real high. I'd suggest you either just scrap the truck, or take it to a shop that knows what they're doing to have it rebuilt. You can get a rebuilt stock 4L60E for around a grand and a race ready unit 1800 bucks (plus installation), this is a lot safer than spending 500 bucks at the wrecking yard for what more likely than not is a pig-in-a-poke.
I'd hazard a guess that on top of the general wear, the tranny is loosing line pressure as it warms up. On the surface without digging deeply into it some common causes of this are a failing Electronic Pressure Control (EPC) motor or its filter, and/or leaky internal seals (many of these are plastic, some require complete disassembly to get at and that's not cheap). So the answer could be simple and not to expensive, too really expensive along with worn clutch packs, leaking servos , swallowed check valves, it has a nasty habit of sucking some of these right thru the hydraulic valve assembly's divider plate.
There are a lot of houses around the country that rebuild these from mild to wild, I get on Google and do some shopping, I think in long run it will prove to be cheaper than attempts at a bargain repair.
Bogie
Old 10-05-2009, 06:17 PM
Ya. This guy is good he is a retired tranny specialist. He is probably one of the best that I know. I'm not going to get a junk yard tranny. He's going to go through the whole thing and and overhaul it.
1995 chevy 1500 4l60e stenichs Transmission - Rearend 2 05-10-2009 02:52 AM
2000 Chevy s10 2.2 with 4l60e problems, No movement Outbound03 Transmission - Rearend 3 04-09-2009 05:50 PM
2001 chevy 1500 4l60E problems ferragus Transmission - Rearend 7 03-29-2009 11:46 PM
4l60E Shifting problems after removal of Compushift clayizzle Transmission - Rearend 1 10-24-2008 07:05 PM
4L60E Shift problems Brain540 Transmission - Rearend 4 08-28-2008 07:46 PM
