1996 chevy suburban trans troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2008, 01:13 AM
about aproblem that I am having with my 1996 chevy suburban i recently brought the truck like five months ago. I just recently put new 22" x 9.5" wheels on itand two days later my transmission went nuts.. first would work fin ... then would only go into low third on the shifter. was making small whining sound from 0-10 then goes away.... Now truck wont move . just snatches in and out of gear real loud and hard. WHAT COULD THIS BE??????????
Old 11-16-2008, 04:50 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Moving to the Transmission forum
Old 11-16-2008, 07:03 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by thizzman
about a problem that I am having with my 1996 chevy suburban i recently brought the truck like five months ago. I just recently put new 22" x 9.5" wheels on it and two days later my transmission went nuts.. first would work fin ... then would only go into low third on the shifter. was making small whining sound from 0-10 then goes away.... Now truck wont move . just snatches in and out of gear real loud and hard. WHAT COULD THIS BE??????????
Mileage on this transmission?
1/2 ton or 3/4 ton vehicle?
Engine size?
4x4 or 2 wheel drive?
Have you checked the fluid level?
Is the fluid dark brown and smell burned?
Sounds like the trans is low on fluid or the filter is clogged up from debris.
454 chevy in 79 trans am, possible? Trans Am Benny Engine 9 12-31-2011 11:06 AM
Chevy engine doesn't fit Chevy Trans! 2000jack Engine 21 01-31-2008 10:51 AM
1996 Chrysler T&C trans problem mcarone Introduce Yourself 1 10-12-2007 06:15 PM
HOW TO MAKE 700R ELECTRONIC TRANS WORK IN 59 Chevy pick up hexx Transmission - Rearend 4 02-11-2007 01:31 PM
1996 Big Block Chevy Wiring Diagram Sick56 Electrical 2 01-02-2006 02:31 PM
