1996 chevy truck transmission woes - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2007, 09:48 AM
i have a 1996 chevy truck ,code reader is picking up an error, not code (2 nd & 3 rd selenoids working same time question is,where are location and which is which
Old 09-29-2007, 10:14 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
1/2 ton truck? 4x4 or 2wd? engine; 4 - 6 - 8 cylinder?
Trans mayb a 4L60E.
what codes? Only picks up an "error" ?
I would suggest hooking up a quality scanner to mayb get better information
what is the trans doing wrong?
Shift solenoids operate separate , yet both are 'on' for certain gear.
Shift solenoids for the 4L60E trans are located on the v-body, next to each other.
chevy 396 truck vs car engine MPCzehura Engine 4 11-28-2006 09:07 AM
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 12:37 AM
looking for a pic - the Navarro (?) families 68/69 chevy truck lowROLLERchevy Hotrodders' Lounge 0 10-03-2006 03:24 AM
Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck TL-Iguana Transmission - Rearend 1 08-22-2004 05:54 AM
questions about 71 chevy truck scrisler Hotrodding Basics 2 09-26-2003 02:29 PM
