1996 chevy z 71 which automatic transmission type? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2012, 07:11 PM
I am in need of some information I am in the process of buying a 96 chevy z 71 has a 5.7 liter I do not know if it is a 4 l 60 e or the 700 r 4 the problem is the battery seems to die and when the battery starts to die you lose third and fourth gear in the transmission this is a transemission problem or is it a electrical problem?
Old 01-25-2012, 08:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.com
I edited the thread title to give the members an idea what the subject question is.
A 1996 1/2 ton GM truck would have the 4L60E trans. Problems with the electrical system will cause troubles with the power train.
I would get the battery problem sorted out and go from there with the transmission.
Out of curiosity , do you know how many miles on the transmission?
Problems with the 3-4 clutch pack is common on the 4L60E trans
Old 01-25-2012, 09:01 PM
I believe the truck has 87600 its never been in the mud its only been in 4 wheel Dr 3 times I know this to be true as its my best friend since childhood
1992 chevy caperice, changing from automatic to standerd transmission marcum75 Hotrodding Basics 0 01-18-2012 01:31 PM
1996 chevy 1500 electronic transmission trouble elcamino78tr Transmission - Rearend 1 01-22-2011 08:15 AM
1996 Dodge b2500 van 4 speed automatic questions boredandglued Transmission - Rearend 2 12-13-2010 06:23 AM
1996 chevy truck transmission woes rogerfrts Transmission - Rearend 1 09-29-2007 10:14 AM
Automatic Transmission Fluid Type A jimra1944 Transmission - Rearend 2 11-21-2005 02:31 AM
