1996 Cummings Diesel - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2007, 10:57 AM
What is the best why to increase the HP. Is the chip the only was. I have heard it decreases the life of the engine.
I use the truck to pull a 40' Toy Hauler and could use more HP.
Old 04-22-2007, 01:56 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
Jim, there are multiple things you can do to increase the hp of your Cummins diesel. Chips/Programmers do not decrease the life of the engine themselves, it all depends on how much you abuse it. I have a programmer in mine and it makes a world of difference, I do not tow with mine loaded any higher than the tow setting, the EGT's (Exhaust Gas Temperatures) get way too high - that's one of the key points.
For your model Cummins, a low hp chip set for towing will work wonders, without harming your engine. Just look at the numerous companies out there and do some research. All you will need is a tow/torque increase, say 70 hp increase.
Injectors are available for yours also from low hp gains to ones set for racing. Get an air intake system and free flow the exhaust and you will see/feel a difference as well. The plus side to the free flowing exhaust is that the EGT's will be lower when the engine is under a load.
Do not be afraid to chip it, the biggest thing it does is increase fuel pressure and advance the timing for the injection system. For instance, '05 Cummins/Auto - mine is set from 70hp to 150hp to 260hp, and torque increases up to 450 ftlbs. I have run mine on long trips at the highest setting, raced the thing, you name it, and it has not missed a lick. A chip would be the most cost effective increase you can get for your Cummins.
Jason
Old 04-22-2007, 03:29 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
You can't put a chip or a programmer in a 96. It does not have a computer. It has the old mechanical pump. Which is a good thing. Cummins made those engine up to 350 hp. Most can be done with just fuel and timing adjustments. The bad thing about the 96 is when you tune more fuel to it for more power it usually decreases fuel mileage. You also need to have a pyrometer (exhaust temp gauge) installed. More fuel in a diesel means more power and more cylinder heat. You can melt the pistons before the water temp gauge will even move. Also if you are towing more fuel means more sooty smoke to get all over that trailer. There are also stop plates to go in the pump to get even more fuel.
Locate an ADS Diesel shop in your area and take the truck there to have the aneroid set and the fuel turned up to it. The Aneroid is a device in the pump that does not turn the fuel on till the boost comes up. Adjust the aneroid will make the truck accelerate a lot quicker but more black smoke.
If you need some help call me. Ron at Acme Diesel 1-800-280-3350
also www.acmediesel.com
Old 04-22-2007, 03:52 PM
41willys's Avatar
Blowin' it
Wiki Edits: 11
Crud, when did the Cummins go to electronics? I assumed that it was early 90"s.
Jason
Old 04-22-2007, 04:00 PM
Cummins went electronic when they intro'ed the high-output 24 valve engine with common rail. They offered the common rail as an option for two years before making it standard. I think it became standard in 1998.
Old 04-22-2007, 05:51 PM
RPM's Avatar
RPM RPM is offline
Cummins went with the electronic control engine in mid 98 it was the 24 valve engine. They started using the common rail fuel system on the 24 valve in 2003.
http://www.centralmotivepower.com/
Is in your town and they are Bosch factory service center. They can fix you up.
Old 04-22-2007, 05:53 PM
My mistake.
Old 04-22-2007, 08:11 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
Check out this site. www.dieselram.com great site they have helped me out a bunch of times. lots of knowledgeable guys when it comes to diesel.
Old 04-22-2007, 11:14 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Technically, 1998.5. The early 1998s were still mechanical.
Jim, even if you decrease the life of that engine by 10%, that means it will only last 360,000 miles instead of 400,000.
I've personally witnessed a 12v cummins make 2131 lb-ft of torque and over 1000 hp to the WHEELS on a daily driven truck. http://www.dieselperformancemotorspo...&g2_itemId=368
When you're towing, EGTs will be your killer. If they're not kept in check you'll melt pistons and otherwise cook the turbo real fast. Just remember that for all the mods you do on the intake/engine/fuel side, make sure you open up the exhaust. With diesels, you can't go too big with exhaust, so don't be afraid to spend good money on a big, good-flowing exhaust first along with a pyrometer to keep an eye on EGT. That alone might get you 50 hp. Now, feel free to add fuel/boost. You should be able to get more power than you could ever need before you hit an EGT problem.
Old 04-23-2007, 07:15 AM
RPM's Avatar
RPM RPM is offline
In most cases the Cummins motors will out last the Dodge body. I have seen a lot of Cummins engine with over half a million miles on them.
Here is a dyno run with some big numbers...
http://www.relentlessdiesel.com/medi...C%201132HP.wmv
Diesel monte......don't hunt me down for writing this Jzarczyn Engine 31 09-05-2006 10:45 PM
stovebolt diesel? jtdiesel Engine 4 08-20-2006 11:12 PM
Diesel truck, should I buy it??? 1931 steve Hotrodders' Lounge 4 08-07-2006 07:34 PM
351 to diesel donnerdog Engine 18 03-15-2006 02:13 PM
cummings diesel onecoomofo Engine 10 04-06-2004 12:54 PM
