Thread Tools Search this Thread share on Facebook
  #1
Old 11-20-2011, 07:16 PM
tim0215 tim0215 is offline
1996 Ford Taurus Transmission Problem
I have a 1996 Ford Taurus GL, w/ a 3.0 litre engine. Recently while going a short distance, the transmission stopped pulling. It will not move in any gear, forward or reverse now. Engine starts fine, revs high initially upon starting now. Before this happened I noticed a pink shaded liquid on garage floor - wasn't exactly oil but maybe tinged with some- it was mostly water. Lastly, I recently replaced the Cv axle on the passenger side. I dont believe this is associated but thought it could be helpful as a reference point.
Any suggestion as to the source of this problem would be helpful to me.
Thanks.
Register now (free) or login to remove ads
Old 11-21-2011, 06:11 AM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Thanks.
either the converter splines in the converter have stripped out or you have internal failure.
id also be looking for intrusion since you say you saw some pinkish fluid on the floor. trans fluid should be cherry red when in good condition.
Old 11-21-2011, 08:42 AM
ethn_bert ethn_bert is offline
Last journal entry: Some More Roll Cage Fabrication
^X2
Very common problem.
Old 11-23-2011, 10:58 PM
10scnd70 10scnd70 is offline
Have you checked the fluid level? AXOD, AXNS, and AX4N transmissions (Taurus) are notorious for stripping the pump shaft splines out of the converter, breaking the pump shafts and stripping the splines out of the pump rotor. They are also known for greanading the pumps. Any of these will cause a "no move" condition.
Frank
Old 11-24-2011, 08:53 AM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
Last journal entry: First week of December
Ahhhh
Taurus/Windstar transmissions
Been there done that----sent it out for repair, and now 2 years later---acting up again.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1996 Ford Taurus Transmission Problem"
ThreadThread StarterForumRepliesLast Post
Ford Taurus will not move in gear.. transmission issues or what?!One to RememberTransmission - Rearend902-13-2012 11:41 AM
1993 Ford Taurus Transmission problemsWanda79Transmission - Rearend105-08-2011 11:41 PM
1996 Z71 4x4 transmission Problemharrelson7Transmission - Rearend403-08-2011 08:24 PM
1996 Ford 460 Exhaust Manifold Problem! Solution?BobnSofiEngine005-10-2007 09:56 PM
1996 ford taurusmychevystangSuspension - Brakes - Steering110-19-2004 01:46 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
