1996 gmc 1500 transmission problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2011, 08:57 AM
My 96 gmc 1500 want shift out of first gear until u get up to about 30 miles an hour and running about 4500 rpm. Then about 55 it will shift into 3rd gear. The check engine light is not on.I had it scanned and it did not show any codes. I'm thinking it's internal. In the valve body or filter or something But I'm not sure if any body could help me out it would be appreciated it has the 4L60E tranny
Old 06-28-2011, 10:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
mileage on the transmission? Any recent work on the vehicle?
does the speed-o function?
Old 07-01-2011, 11:17 AM
It's got 190000 on the truck and not sure on any recent work done to it I bought it with this problem and I think the speed o is working I was told bye a Tecnician that if the speed o meter was workin than the speed o was fine then they told me to see if I had twelve volts going to the pig tail plug on the passages side of tranny and if it had twelve volts on it and still not shifting right then I need to pull the tranny and have it fixed and it doesnt show any codes
Old 07-01-2011, 11:31 AM
tnsmith10's Avatar
when will it rain???
that information on a 4l60e would be inaccurate. if the 4l60e does not have +12v going to the trans, it will have 3rd gear take off, and manual 2nd only, and not shift.
does the speedometer drop out at all? from what ive seen with what your describing, 9 times out of 10, its the v.s.s. which depending on whether its 4x4 or not, will determine where the v.s.s. was put.
best thing to do would to borrow a scan tool with a live datastream, and see if the datastream shows if the v.s.s. is reading properly along with vehicle movement. if it satys at zero without coming up with vehicle speed, then all of a sudden pick up, then more than likely its going to be the v.s.s.
Old 07-01-2011, 03:30 PM
It doesn't hesitate at all and it starts off in first and won't shift two second until you get up to about 30 mps and comes out of second about 50 mps could it be the shift solenoids or would the show up on the codes when I had it scanned Thanx for info how could I check the v. S. S.
1996 chevy 1500 electronic transmission trouble elcamino78tr Transmission - Rearend 1 01-22-2011 08:15 AM
1996 GMC 4L60e ovehaul transmission; having some problems redmex Transmission - Rearend 1 09-07-2009 08:44 AM
97 gmc 1500 97 GMC 1500 Internal transmission squeak Longbox262 Transmission - Rearend 5 06-25-2008 05:41 PM
My 1996 Chevy Z71 CK 1500 tranny SULLY 1 Introduce Yourself 1 11-15-2004 08:32 AM
1996 Chevy 1500 Truck 4.3 V-6 Juicer Engine 8 09-28-2004 06:06 AM
