1996 GMC 4L60e ovehaul transmission; having some problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2009, 04:27 PM
Ok got a 96 GMC Sierra 4X4 Z71 1500 with 4L60E Transmission, started to have problems and decided to do a overhaul, got all new clutches and plates and had to buy a new forward clutch assy do to some damage. The transmission is done and on the vehicle but runs more crappie than before it did not want to go on first or reverse at the beginning so I added more fluids, well it goes in all gears now but it is overheating and it feel like is in 4X4 or if I was towing a trailer, it is also spilling fluid from the vent line or it was I havenít seen it drip any more, at first I was thinking I had air in the lines sense I had flush the system , but I been running the vehicle for about 3 hours and it seems to be getting worse the more I drive it, Anybody that has an idea or suggestions is welcome
Old 09-07-2009, 09:44 AM
first step try double checking the fluid.blowing fluid out of the vent can be caused by overfilling or a clogged filter or overheating.on another note did you flush the cooler before the trans went back in,on a 4l60-e the transmission is electronically controlled and debree from when the trans went bad could easily stick valves or solenoids.
try better description is it slipping,or feel like its binding.is it shifting normal and does it have any check engine lights on?
1993 4L60e shift problems GSXR-Robb Transmission - Rearend 3 04-12-2009 09:29 PM
4l60e problems ed mcgee Transmission - Rearend 1 04-12-2009 12:04 AM
4L60E transmission nastburns Transmission - Rearend 1 03-26-2009 03:22 PM
4L60E Shifting Problems Garethray Transmission - Rearend 3 05-14-2008 09:50 AM
1991 Chevrolet K2500 4X4 transmission problems Craig Eppley Transmission - Rearend 15 02-25-2008 06:02 PM
