Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996 K1500 4L60E problems
Old 10-06-2012, 11:46 AM
pricesgarages's Avatar
pricesgarages pricesgarages is offline
was the l & r clutches the only thing burnt did u take the sprags apart or replace them if the one in the rear was installed upside down could cause that did u place the vb bolts in the right spot 3 are longer and can bind up the planetary gears if installed in the wrong hole
The Following User Says Thank You to pricesgarages For This Useful Post:
HarperValleyPTA (10-07-2012)
