Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996 K1500 4L60E problems
Old 10-06-2012, 12:42 PM
HarperValleyPTA HarperValleyPTA is offline
I did take the sprags apart, cleaned, inspected, and put back together, according to the 4L60E manual, I installed them the right way, but if I go back in, now I have a place to start. I kept track of the VB bolts but now I am going to pull the pan and double check the bolt locations, re torque them in sequence, and try again. I also replaced the boost valve, but I can feel the pressure and see the RPM's drop when in reverse.
