Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996 K1500 4L60E problems
Old 10-07-2012, 10:47 AM
pricesgarages's Avatar
pricesgarages pricesgarages is offline
u did change the lip seals in the low and rev piston ? i seen many people put new clutches and not replace the seals wich makes the clutches work did u remove the check ball at the rear of the case check the 3 8mm bolts on the sep plate retainer
also the pressure switch its the flat electrical piece on the vb if its bad or one of the seals fell out of it it can do the same thing most gm dealers have in stock for around 40
The Following User Says Thank You to pricesgarages For This Useful Post:
HarperValleyPTA (10-07-2012)
