Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996 Mercury Grand Marquis Heater Control Valve?
  #18 (permalink)
Old 01-02-2012, 06:32 AM
Blown496 Blown496 is offline
Originally Posted by dstones
Hi Coodeville,
I'm having the same issue with my 1995 Marquis. Did you get to replace the heater control valve? And if so, did it work out for you?
I'm hoping its not the unit on the dash side, the manual is calling it a heater and AC control assembly..
If the control unit goes bad it will only blow in defrost mode. That is just $.40 of o-rings and easy to fix.
