Thread Tools Search this Thread share on Facebook
  #16
Old 01-01-2012, 04:03 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
Originally Posted by latech
That is not a valve, it is the ambient temp sensor for the HVAC auto system. There isnt a valve on this car. It has a blend door and probably has a stuck blend door motor/actuator.
If you open the glove box and pull it out, look over the top of the heater box towards the dash center, the actuator is there. With the key on and the temp turned to hot, beat on it or tap on it with a little hammer, try moving the temp knob when you are doing this then turn it to hot. Chances are you will get it moving again. LA Tech
Oh and there is nothing under the intake but the hose.If you ever replace it use a high quality high silicone hose and re use the constant tension clamp....yes that is what they are called.Gear drive clamps will allways need to be retightened after an install, constant tension is just what it says, constant tension.They are far better clamps, as the hose softens it just keeps tightening all by itself, no need to remove the intake to retighten
X2.
However, if the control motor is sticking, about 8 of 10 have a stripped gear inside of them. Replacement requires pulling the dash assembly back about a foot... PITA.... I did quite a few of these when I was with Ford. Common issue.
Register now (free) or login to remove ads
Old 01-02-2012, 03:26 AM
Coodeville Coodeville is offline
I'm going to do this and see what happens. Thanks! Mine is still blowing cold.
Old 01-02-2012, 06:32 AM
Blown496 Blown496 is online now
Originally Posted by dstones
Hi Coodeville,
I'm having the same issue with my 1995 Marquis. Did you get to replace the heater control valve? And if so, did it work out for you?
I'm hoping its not the unit on the dash side, the manual is calling it a heater and AC control assembly..
Thanks!
dstones
If the control unit goes bad it will only blow in defrost mode. That is just $.40 of o-rings and easy to fix.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1996 Mercury Grand Marquis Heater Control Valve?"
ThreadThread StarterForumRepliesLast Post
Heater control valve1969chevyssHotrodding Basics109-05-2011 08:34 PM
73 Mercury Marquis Engine Swap oil panRatoflicEngine307-04-2011 06:54 AM
Anyone Know of a Heater Control Valve Than Actuates w/12v??TominatorGeneral Rodding Tech111-01-2007 06:08 PM
87 Mercury Grand MarquisdgpopwellEngine408-30-2005 10:33 PM
Heater control valve questionHotRodF100Engine205-23-2002 03:15 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
