Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 04-05-2005, 05:46 PM
64Joker's Avatar
64Joker 64Joker is offline
64Joker
1996 Pontiac Trans AM Paint Color Code ?
Can someone help me with identifying where the paint color code is located on a 1996 Pontiac Trans AM? Thanks in advance.....
Old 04-05-2005, 05:51 PM
Nightfire's Avatar
Nightfire Nightfire is offline
Young & Idealistic
 Nightfire's barnstar
Wiki Edits: 4
re: 1996 Pontiac Trans AM Paint Color Code ?
Users manual? Thats were it was on our '96 Dodge.
Mike
Old 04-05-2005, 06:23 PM
ckucia ckucia is offline
I'd check either the glovebox, or on the floor of the trunk.
Old 04-05-2005, 08:31 PM
daimon1054's Avatar
daimon1054 daimon1054 is offline
There is usualy a tag on the glove box door but as it's a 96 if it's not there the dealer would know as should most paint shops. These days there are only a few and most are now on file somewhere.
Old 04-07-2005, 04:38 PM
nick62877 nick62877 is offline
should be in the glove box. it will start out with WA then a series of numbers and or letters.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1996 Pontiac Trans AM Paint Color Code ?"
1983 pontiac firebird trans am low77ride Engine 4 06-11-2004 07:29 PM
Advice on Pontiac rearend/ trans swap Vaughn68 Transmission - Rearend 3 11-25-2003 07:38 AM
Right clutch for Pontiac saginaw trans Bandit79 Transmission - Rearend 3 09-15-2003 08:31 AM
1st painting nova33 Body - Exterior 19 06-16-2003 10:05 AM
Pontiac grill paint Vaughn68 Body - Exterior 1 02-26-2003 06:04 PM
