Thread Tools Search this Thread share on Facebook
  #1
Old 06-10-2011, 02:08 PM
boneyard Buick's Avatar
boneyard Buick boneyard Buick is offline
1996 Sierra Crew, 6.5 to 5.9 cummins.. Wiring.
Hey all
havent posted on the board in quite some time, not sure if there are any Diesel Gurus on here but i figured id do a post and see if anyone could help me out
Anyways I got a 96 sierra crew with a '93 5.9 IC cummins sitting in the engine bay now.. scrapped the dead 6.5. truck was an ex 4l80E. now a 5 spd. Now my big questions are... What does the 6.5 computer control? can it be removed and all wires coming out of it into the engine bay? I want to keep my ABS, does the computer control this? Also the tranny was taken out and the harness was just 'Cut' but are all loomed together, around 10 wires or so.. could i trace these wires that were going to the auto trans and into the engine bay harness just eliminate these as well?
My main concern is the computer and wires heading into the engine bay from the computer..
i know the wires that i do need (switched +, Glow relay power to run fuel shutoff, Alternator, temp, oil gauge. Guess I just have to put the wires i DO need to the side and trace the wires i dont use and eliminate?
thanks in advance, i hate wiring
Register now (free) or login to remove ads
Old 06-10-2011, 07:37 PM
HalfOunce HalfOunce is offline
the abs has its own control module separate of the pcm, however the abs control module does receive a signal from the pcm for 4wd input. wiring diagrams for both vehicles in my opinion are essential.
Old 08-07-2011, 10:19 AM
t00lmanii t00lmanii is offline
how did your swap turn out? Did you get all your wiring finished, and what all were you able to salvage.........original speedo, cruise....etc???? I'm in the middle of wiring my 5.9 Cummins into my 97 4x4 Suburban and could use any guidance that you can give. Thanks
Old 08-07-2011, 10:41 AM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 08
The first thing to do is invest in detailed shop manuals for both vehicles at www.alldatadiy.com
vicrod
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1996 Sierra Crew, 6.5 to 5.9 cummins.. Wiring."
ThreadThread StarterForumRepliesLast Post
Wiring Tach - 88 SierraLGhostElectrical203-18-2011 10:40 PM
1996 460 efi swap wiring.JaredElectrical1011-19-2006 12:18 AM
1996 Big Block Chevy Wiring DiagramSick56Electrical201-02-2006 02:31 PM
'78 sierra classic power window wiring schematicjdoreElectrical108-19-2003 10:56 AM
'85 GMC Sierra-factory stereo wiring?Amie89Electrical406-26-2003 12:55 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
