Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996 Vortec Engine Swap - need Help
Old 08-18-2003, 06:35 PM
Adam Mclaughlin Adam Mclaughlin is offline
New Member
Okay guys.
I bought a 1996 Vortec 350 out of a suburban and I swapped it into my 1989 TBI Chevy truck.
I got the wiring harness, computer, complete motor and all of the sensors.
I hooked up all of the wiring as shown by all data, and I did this as follows.
The pink wires are hot when in run, the orange hot all of the time, and the yellow hot when cranking.
I have a the motor cranking when I go to start it, and I have spark, along with 48 psi of fuel pressure when system on, engine off.
The darn thing won't start. I have check engine light, so I know it is alive, but I am not sure why it won't start. On the injectors I show about 9 V when cranking from the open connector.
What gives? Does it have VAT that must be in the loop to make it start?
In other cars I have done similar swaps the machine at least starts and runs for 2 secs before the VAT makes it drop out. This thing does't do anything but crank.
I did pull the distributor out and re set it when I noticed my original one was cracked. I brought the motor to TDC of cylinder #1 and then aligned the distributor to point at pole #1 in that corner of the cap.
What gives guys? I got a couple of puts out of it, but other than that I have no signs of engine life.
I have access to another 1997 Vortec I could compare too, but this isn't helping much at this point.
Any suggestions out there?
I want to get my truck back on the road!
