Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1996 Vortec Engine Swap - need Help
Old 01-03-2005, 09:56 AM
bluesman123's Avatar
bluesman123 bluesman123 is offline
I didn't change my fuel lines, but I started with a TPI setup that already had steel supply and return lines. If your's started with a carb, I would change them. You will be going from 10-13 psi to 60-65 psi and there might be a connector somewhere that can't handle it.
It will definitely be easier to plumb it if the lines come up the driver's side.
Bluesman
