-   -   1996 Voyager/Caravan Wipers not working (http://www.hotrodders.com/forum/1996-voyager-caravan-wipers-not-working-225657.html)
pemdj 11-02-2012 01:30 PM
I have a 1996 Plmouth Voyager , Wipers stopped working , they only work when I push the washer at the end of turn signal handle. I have power to the wiper switch. Also I tested the wiper switch with a digital Ohm meter and it tested good . I have 12 volts on the Red wire with a Violet Stripe going from the BCM to the wiper Relay. I tried swapping the relays. When I put a test light to the Red wire with the Violet stripe the wipers would work. .
ANY ADVISE ???
Thanks Phil
