Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1997 4l60e problems..
Old 01-21-2009, 08:50 PM
cheezehead69 cheezehead69 is offline
I checked the solenoids with an ohm meter. They where all within the peramaters that the manual showed. It never jumps from gear to gear. The tranny doesnt hunt for gears what it does it when you apply slight throttle it revs up about 500 to 800 rpm and then drops into gear. and it dosent slowly drop in it hits and almost jumps the truck forword. you can feel it. now it only does this when the rpms are around 1000 to 1600. if you are cruzing at a constant speed it dosent have the problem only when you slow dow and the lightly accelerate to maintain speed or slowly increase speed. the original failure was about 300 000 km of abuse and slipping in 1st, 4th and a huge hesitation from park to anygear.
