Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1997 4l60e problems..
Old 03-26-2009, 07:40 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Solenoids can fail hydraulically and test fine with ohm meter.
Sounds like you have a internal leak. Perhaps mis installed parts during your parts replacement on this trans?
Perhaps you missed a bad worn area for the sealing rings or cut a sealing ring during the parts replacement?
