1997 Blazer 4.3L V6 L35 Fuel Injection - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2008, 04:11 PM
Hello
what Fuel Injection System has my 1997 Blazer 4.3L V6 L35.
Is it a Monopoit Injector ?
How many O2 sensors do I have?
monette999
Old 02-23-2008, 05:31 PM
re: 1997 blazer 4.3 l
Hi ok to my understanding monopoint is a single injector in the throttle body or you will have 1 per cylinder in the manifold with spider wires running to them, 1 per cylinder is multiport, as far as 02 sensors most have 1 but you may have 2, 1 per side on the exhaust manifold or the pipe right after TROY
Old 02-23-2008, 05:48 PM
DoubleVision's Avatar
It should have 3 Oxygen sensors. My fathers 98 chevy pickup with the same engine does. One for each bank and another right before the cat converter.
Old 02-23-2008, 11:11 PM
sbchevfreak's Avatar
Licenced Automotive Technician
You have what is known as CPFI. There are 6 injectors in a central "pod", with "spider" or capillary tubes running to poppet nozzels in the intake ports. As for O2's, you should have one in each pipe coming down from the manifols, and one AFTER the converter.
Old 02-23-2008, 11:31 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
As the above post's you do have 3 0'2 sensors. The injection unit is called a CPI Fuel injection. I wonder why you are asking for this information. Are you having a starting or drive ability issue?
Old 02-24-2008, 01:15 PM
Vortech 4.3's Avatar
jack of all trades
it should have 4 O2's, left, right, 1 before and 1 after the cat.
that is the "SFI" fuel injection, 96+. it has 6 injectors in a central block.
"CPI" has 1 throttle body type injector in a central block. that goes out to 6 poppets.
Old 02-25-2008, 10:17 AM
Vortech,
if it is a L35 engine. What do I have ?
do you need the VIN ?
monette999
Old 02-25-2008, 10:55 AM
I like to convert my Blazer to Liquid Petrolium Gas Injection.
LPG in Europe or Autogas, or GPL.
regards.
Old 02-25-2008, 06:43 PM
jack of all trades
you have an SFI. check out the s10forum.com forums.
Fuel Injection Fuel line Plumbing william27103 Engine 9 06-10-2011 05:22 PM
96 blazer fuel pump ricksautorestoration Engine 15 06-07-2009 02:16 PM
94 firebird: What's needed to delete Fuel Injection lostinthought Hotrodding Basics 5 10-28-2006 04:19 PM
fuel injection ignition Blob Engine 5 12-26-2004 05:15 AM
transmissions fit 97 s10 ss 4.3l v6? boylanta Transmission - Rearend 5 08-24-2003 05:56 PM
