Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1997 blazer..Brake booster gone bad?
Old 06-16-2005, 10:57 AM
sedan delivery's Avatar
sedan delivery sedan delivery is offline
booster
this sounds like a bad booster when you hear air leaking under the dash. the diaphragm has a hole in it. this is what gives the brakes the boost. so the booster needs to be replaced or overhauled , which ever one you can handle. it is much easer to exchange it at you local parts supply. good luck
