Thread Tools Search this Thread share on Facebook
  #1
Old 06-16-2005, 06:13 AM
RodFather's Avatar
RodFather RodFather is offline
I smell like a hotrod!
Last journal entry: windshield
1997 blazer..Brake booster gone bad?
A friend said her brake pedal was hard to push down. I went over and replaced the check valve on the brake booster, but it was fine. Pushing on the brake which is a little harder than normal would stop the car, but feel like the brakes weren't grabbing enough to bring it to a stop.
When pushing on the brake you hear a noise like something is loosing air (noise is coming from behind the brake pedal).
I am going in the right direction with replacing the brake booster?
Register now (free) or login to remove ads
Old 06-16-2005, 10:57 AM
sedan delivery's Avatar
sedan delivery sedan delivery is offline
booster
this sounds like a bad booster when you hear air leaking under the dash. the diaphragm has a hole in it. this is what gives the brakes the boost. so the booster needs to be replaced or overhauled , which ever one you can handle. it is much easer to exchange it at you local parts supply. good luck
Old 06-17-2005, 01:26 PM
RodFather's Avatar
Brake booster replaced, and everything works fine.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1997 blazer..Brake booster gone bad?"
ThreadThread StarterForumRepliesLast Post
Bad brake booster?NOlowriderSuspension - Brakes - Steering405-26-2005 12:39 PM
1988 chevy s-10 blazer, and i want to put a 327 in it. comments, good idea bad idea.1969cssIntroduce Yourself112-22-2004 05:18 AM
brake booster gone?73chevyhelpSuspension - Brakes - Steering1411-21-2004 01:00 AM
Brake Booster - Hard to change?RapidRoySuspension - Brakes - Steering209-15-2004 08:19 AM
brake boosteranthony herreraEngine102-03-2003 08:00 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
