1997 blazer has a bad 4L60E I have a goodwrench rebilt 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2012, 11:22 PM
I'm not a real wrench, I have been reading up on the 4L60E I understand they have some weak thrust washers and sun shell something, and some computer control may have changed in mid 97. the tranny in the bazer now has the two pc. bell housing, the on I have on the bench has a one pc.type with bottom of the bell at about a 60degree angle I guess it's a700R4. if it will fit what else would it need other than a dust cover.the current engine is a 2004 4.3l. I let the vehicle set for about 40 days, when I started driving it again I lost reverse than 2,3and4. topped it off with fluid .that didn't fix it. any help is greatly appreciated.
Old 08-21-2012, 12:26 AM
joshp83's Avatar
owner of Prices Garage
u need to use a 1997-04 4l60e there are many changes from a 700r to a late 4l60
Old 08-21-2012, 07:06 AM
Non SPI THUG/Not Sheeppeople
Last journal entry: 700r4 still running strong
A 4l60e will have 6 bolts holding on the tail shaft housing,a 700r4 will have 4.Also a 700 will have a 4 pin connector on it,a 4l60e has a lot more.
1997 chev blazer master cylinder melmarkford Suspension - Brakes - Steering 1 05-05-2011 04:09 PM
1997 4l60e problems.. cheezehead69 Transmission - Rearend 6 03-27-2009 06:10 PM
1997 Blazer 4.3L V6 L35 Fuel Injection monette999 Engine 8 02-25-2008 06:43 PM
1997 blazer..Brake booster gone bad? RodFather Suspension - Brakes - Steering 2 06-17-2005 01:26 PM
