1997 buick 3800SC question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 06:25 PM
I read recently that the Buick 3800 SC series 2 engines have "Rod BOLTS" that are "torque to yield", making them "non reusable". IS this True ?? So, if I wanted to check the rod and main bearings before installing this engine, once I took off the rod caps, I can no longer just re-torque "without having to replace the rod bolts" ?? This doesn't sound reasonable. Can someone verify if this is TRUE ?? Thanks
Old 04-04-2013, 08:03 PM
evolvo's Avatar
Most likely they are torque to yield and shouldn't be reused. ZZPerformance sell a set of ARP bolts for $99.
ARP - ARP Connecting Rod Bolts - Series II #ARP-123-6002
Old 04-04-2013, 11:36 PM
Tty rod bolts ?
I've heard of TTY "HEAD" bolts, but TTY "ROD Bolts" ? That means just to check the rod bearings, you have to pull the heads, pull the pistons and rods to replace the "Bolts", That's insane !
1997 gmc starting question jjupiter100 Engine 1 03-09-2010 01:30 PM
1997 5.7L intake question jjupiter100 Engine 3 03-03-2010 09:06 PM
1997 Riviera Fuel pump question. 58lincoln General Rodding Tech 8 01-20-2009 09:54 PM
How bout Blown Buick (1997 style) BlownBirdy Engine 0 12-12-2003 10:18 PM
Fiero guy here with 375HP 3800SC engine FastFieros Hotrodders' Lounge 0 10-06-2003 10:07 PM
