1997 chev blazer master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2011, 02:12 PM
MAF
Hello,
I have a chance to purchaser my neighbors 1997 blazer that I have some speciel use for. It has been sitting for long periods of time and we live on the water. Most of the brake lines rusted out and I have replaced them.
No leaks and still no pressure. Put new master cylinder on and bench bled cylinder prior to installation. When pumping breaks to bleed lines, rotors and wheel cylinders brake fluid is pushing into the resevior cannister closes to the firewall and no fluid or air is purging at the bleeder valves. Any and all help/sugestions welcome. Mechanical skill above average, spelling not so well!
Thanks,
Mark
Old 05-05-2011, 04:09 PM
adamh-h9780's Avatar
does it have a brake boost? if new master cyl/lines the only thing left would be boost. but im not sure just guessin
1997 Blazer 4.3L V6 L35 Fuel Injection monette999 Engine 8 02-25-2008 06:43 PM
Master Cylinder Pedal Assy 53 Chev PU 53 5WNDO Suspension - Brakes - Steering 0 03-29-2007 12:03 PM
Has anybody used a Chev Astro van booster/master cylinder for the 48 chev truck tomy2tone01 Suspension - Brakes - Steering 2 04-07-2003 05:05 PM
1966 Chev PU upgrade to dual master cylinder for existing brakes Bannear Suspension - Brakes - Steering 7 10-23-2002 01:15 PM
